toyota 8in detroit locker broken?
dove'd85
kenmore WA
okay so i have yet to tear my front end apart but i know that something is broken in my front axle, i have a full detroit in the front with longfeilds so one side spins and the other side doesn't it just makes like a ratcheting sounds when i lock the hub in and spin the tire?:eeek: :booo: :masturbanana[1]:
Congrats you now have a $450 paper weight. I think it was northridge 4x that could get parts for them... Or maybe it was aventeone... Someone could do it I know that...
if thats the case i have a pair of $450 paper weights because they are both acting up. i haven't torn into the one that i have out yet... :masturbanana[1]:
Yota detroits have no warranty if you break an axle for a reason... They suck. :haha: Best bet is to see if you lucked out and you can fix one with parts from the other.
does anyone have any experience in taking a full detroit apart? i am not sure what to expect? do i just take out all the allen heads and split the two halves or is it more complicated then that? thanks
james
The preferred method is a piece of allthread /w a large washer and nut on each end. Unbolt the case halves, then slowly pull it apart. There is a large spring inside and if you just unbolt it and aren't prepared, it will pop apart and pieces go everywhere :)
And yes, I can get you parts for it.
John
I just clamped mine in a vise and removed the bolts then let the vise loose. They are pretty damn simple, but if you broke a shaft its pretty common to break a side gear in the locker. Too bad they don't make a 300m detroit locker.:beer:
John[/QUOTE]
Can you get dana 60 detroit parts? I need a clutch assembly.
You can get them from detriot out of poland.[/QUOTE]
Only if you have an in, they don't offer replacement part's to the public 99% of the time, if they'll warranty the whole locker is the only way your getting fixed. As far as I know, very few people can get part's (us being one of them) we get clutch and hold out ring's for broken detroit's pretty often. Don't be overwhelmed, there's only like 9 or so part's inside a detroit locker. I just pull the bolt's and hold it together between my hand and a bench, it doesn't take much pressure to put it back together either. I don't like the all thread method because thing's have to line up on the way back together and if I'm not doing it by hand I can't feel if it's all good.
too much for junk to break and not get parts for. is it a fluke that the most expensive non selectable locker is not serviceable (available parts). I dont run one for that reason. actually I just lied. my front rockwell has one. hope I never break it:mad: . oh well I got it for free.:beer:
Other than getting parts from me, some dealers do sell service parts. The problem is that some dealers just don't like the hassle. Tom's Differentials sells and stocks a bunch of parts.
Darius mentioned not liking the all-thread way of assembly. Using all-thread is far easier than any other method. If you have cleaned and dried all the internal parts, you use grease to hold pieces in place. I can usually disassemble and reassemble a Detroit in about 30 mins.
PM me for parts.
PM me for parts.
PM sent:awesomework:
