stuftmunky2k
well tearing into the front axle of the rig for some maintenance found a few things interesting seeing if anybody could give a little insight. Axles are regular mini truck, but anyways found my longfield on driver side pretty much useless has no movement left in the joint at all, pretty much have to beat it with a hammer to get it to move and was a hell of a job to get the shaft out. The thing that concerns me is I replaced the inner axle seal this past summer it was worn like an oval towards the top side. Tore the axle apart this time same thing, knuckle filled with oil and seal worn all to hell on the top side. Im pondering the fact that the housing might be a little bent but have no clue on how to check it for straightness. The axle has six shooter knuckles and the drive side did feel a little loose like it need a shim taken out but how can this happen when its ran for couple years with no issue and now all the sudden the front axle hates me and life. I understand if the knuckle somehow worked loose then it would throw everything out of whack. Don't want to throw bunch of money at a problem if its just the housing bent. any insight on what you might think or how to check the housing for straightness would be much appreciated. the housing also has an upper and lower truss so really the only thing could be that the ball might be bent up?
no telling how those little sheetmetal housings are tweaked around though.
