toyota axle ratio help
Crvett69
New Member
i have a 95 4runner i am going to strip for parts and i was wondering if there was a way to tell from serial number or some numbers on the door post sticker what the ratio is. the number on the door post is A/TMG292/G58. i looked under hood but not see a data plate there. any help would be apreciated
usually if you pull the driveshaft off the diff pinion nut has color coded paint on it. That how I usually do it when junkyard scrounging thirds etc.
Pirate4x4.com Toy FAQ has the color code chart.
im pretty sure red is 3.73, pink is 4.10, and white is 4.56. not 100%on that but im pretty sure that is right.
