Toyota axle removal..
Dubshot
Puyallup
How do I remove the steering shaft from box to axle? everything undermine is dirt,mud, and oil and cant seem to find a way.. Also where would I remove the brake lines at??
Take the cotter pin out, get a big flathead screwdriver and the "slug" unscrews. Might need to use a screwdriver with a wrench flat, the slugs can be in there pretty tight. there will be a spring and a "cup" (the ball seats in it) that are loose inside after the slug is out. Pull and wiggle the arm and it will come off, rocking the steering wheel helps to. Repeat the same process for both ends.
