Clark
i've got an elocker i want to pull out of a 4runner, what elses should i take besides the complete thrid member? will i be better off with an aftermarket switch?
that switch setup sounds great, i'll do that when/if i install it. I have this 97 4runner, and i'm going to take out the elocker, and want to make sure i don't leave anything in there i will need.
Can i replace a v6 elocker rear with an open 4cyl? assuming the gear ratio's are the same
wow, another good one, you are the man, i owe you one:beer:
http://home.4x4wire.com/erik/diffs/#front
if you scroll to the bottom there are some links to wiring diagrams and install info into a standard 8" housing.
thier diagrams are full of uneeded circuts. Its a normal current reverse like doing door lock relays. Only the diff has a ground interupt switch so it cant be burned up if held on.
I did use thier diagram to decipher the stock wire functions and then simplified it from there.
Tons of great info there, just so much its overwhelming. I printed about 11 pages form that link and gave it to the last guy I installed an Elocker for. He was sure he could get the factory harness and just find a relay computer in a yard and plug it all in!!!!!:haha::haha:
I told him to let me make a simple harness, he persisted that stock toyot wiring was the way to go. It took him 2 weeks to give up on the toyota dealer and OEM harnesses. Then it took a week of him staring at the overcomplicated and three different ways shown to wire them before he gave up on that.
They suggest you find a double pole, double throw switch, then a strange way to wire it.
NORMAL GEARHEADS WILL DO ANYTHING TO AVOID USING RELAYS! It is was way simple with two relays, not the switch thing they recomend.:beer:
**** the bull **** and make it a cable locker:awesomework:
