Toyota fuel pump
Will this work
  • Toyota
    Votes: 0 0.0%
  • Toyota 2
    Votes: 0 0.0%
  • Total voters
Well it burn the pump up?? Cause I wired mine to a switch and ran fine . Then went to start truck and fuel pump didn't come on . Replaced switch then check pump and pump is now bad !
Not sure the switch has 3 places power , acc., ground . So I went from batt. To swicth . Switch to pump , grounded the switch in the cab and grounded the pump ground to frame ... Hope this make since . I'm new at this
