They are next to impossible to find anywhere else.
If you call randys or simular places they will tell you they have them and will send you shims that are huge and go under the outer race, not under the inner bearing. I have 5 packs a large shims I have bought that were sold to me as pinion shims and are not what I wanted.
I ended up getting machine washers from McGuire bearing in tacoma in 30 75 and 95 tho thicknesses for bulk buildup
Thanks for the info chop shop, I almost ordered the randy ones, ya thoseI shims are impossible to find! and ill be giving you a call shortly xo, thanks,
No, they are the same thickness, but if you stack the stock one and one of these tacoma screw ones and then roughly 2 of the thin pinionhead bearing shims you will be around the right depth. I just did 2 diff.s this last week using this method. I dont like doing this but 4 wheel parts sells the same r/p for 4 or6 cyl. Diff.s
Ohh and they charge more for v6 too!
4 wheel parts sells their toyota r/p with a 10 year warrenty fyi.
