I have a Power steering cooler and also want to throw in a electro secondary fan. should I try and get the fan and the cooler on the front of the radiator or put the cooler on the back/inside of the radiator and electro out front?
are you running the stock clutch fan? i'd run it where ever you have the most room.. just make sure the electro fan is pull/pushing air in the same direction as your existing fan
yes im running the stock clutch fan. The box for the cooler says if yoU put it on the inside of the radiator your working the cooler at 60% of its potential since its on the other side of the radiator your blowing hotter air through it. and theres more restriction because of it. just looking for peoples opinions or what they have done.
I swapped it to the inside for clearance and with the secondary fan id think it would cool just fine.. had it on the outside but didnt want to chope the crap out of the core support for a fan.
