actual axle strengths? I have never owned a pre 86 rear diff, but the ifs 4 and 6 cylinders diffs use the same axle shafts.
as far as housings go the later ifs diff housings are stronger with larger tubes.
The V6 thirds are a bit stronger. They have more ribbing (for pleasure ) on the outside and I believe the pinion bearings are larger
And I forgot they are a 4 pinion design in the carrier which is muy bienThey can also hold a stronger gearset. :;
Isn't the 9-inch built from sheet metal too? :flipoff:Are you gonna build an EXO cage around the sheet metal axle to protect it too?
There's always a hater in every crowd :fawkdancesmiley:Are you gonna build an EXO cage around the sheet metal axle to protect it too?
Yeah, but for the most part it's only the Yota guys that are worried about their sheet metal :haha:
