2pwrlftrs4u
NWW Meanie
whats the best budget rear disc conversion for a Toy 8" axle. which rotors/callipers, ect. did you use.
You guys don't go to PBB at all do you? :haha:
right..like you could find anything on there.You guys don't go to PBB at all do you? :haha:
Front rotors from a 92 chev 1/2 ton 4x4, non HD(rotors are thicker on HD & wont work). Lathe center to fit axle stub.
Brackets from Sky, Ruff Stuff, etc.
Calipers to fit brackets. Monte Carlo, Taco, etc.
Its all very basic.
Personally I've got 90 2wd front calipers, generic 4x IFS rotors and once i get off my ass I'll build some caliper brackets. I'll be in the whole setup for the price of new pads in teh calipers.
The GM swap is pretty standard these days but if you have rear spacers re-using solid axle rotors and calipers with a set of prefabbed brackets is the cheapest for you....
i thank you sir:;91-97 NON abs fj-80.
I just so happen to have a pair of 4 cylinder calipers sitting in the shop... What are they worth to ya?![]()
pm sent.yes ifs calipers.... Hook me up with a set of pads for 90 2wd 4 cyl calipers and Ill call it square.
