Toyota tech
85buggy
Is there room to pass ?
Ellijay Georgia
My 22r on propane smoke like cheech ang Chong. It's white smoke.
Uses no water and only a acceptable amount of oil. Rarely put any in it.
Does not smoke all the time and not even in the same circumstances.
Usually during high rpms for an extended amount of time. Any idea what
Might b the problem. Thx
Re: Toyota tech
Maybe it is pumping the oil to the top of the head and it is being pulled in by the intake valve guides? Does it smell like oil smoke or fuel?
I had a 22r one time that I couldn't run the straight breather on the valvecover hooked to the air cleaner. It had so much blowby it would foul the plugs under high rpms. We pinched the hose off tryin to figure out what was wrong and it blew the dipstick out and about 2 quarts of oil. I put one of those cheap parts store cone filters on the valvecover and it fixed the running bad problem. It would blow liquid oil through the little breather filter then. :****:
