Sold/Expired Trail-Gear 4 Link Suspension Kit & parts CCOR Special
CCOR
706-559-9609
Athens, GA
Trail-Link Four™ Rear Link Suspension Kit
Four-linking your rig the easy way with the Trail-Link Four™ kit. Innovative design allows for quick and easy installation. Crossmember fits between frame rails and supplies frame mounts for all four links. Choice of axle mounting for stock axle or Trail-Gear Rock Assault™ housing.
Note: Kit does not include shocks, recommended shocks, 16" coil-over, or air shocks. Requires replacing or relocating gas tank. Extensive bed modifications or removal of the bed is required for installation.
This kit works great with our air shock hoop mounting kit.
Kit Includes:
(2) 36", 2"OD X .250" wall DOM links
(2) 28", 2"OD X .250" wall DOM links
(8) 1.25" Creeper Joints (4 right, 4 left)
(8) Rod end jam nuts
(8) Threaded link end bungs
(1) Frame crossmember
(1) Axle housing upper mount
(2) 20 Degree axle housing lower mounts (left and right)
(2) Shock mounts with bolts, and bushings
(8) 9/16" X 4" link end bolts and lock nuts
Available Options:
Trail-Link Four™ Rear Kit, OEM Housing, 140226-1-KIT, Post Up or Call for Price
Trail-Link Four™ Rear Kit, Rock Assault™ Housing, 140225-1-KIT, Post Up or Call for Price
Trail-Link Four™ Rear 4-Link Kit with 16" Fox Air Shocks
Note: Requires replacing or relocating gas tank. Extensive bed modifications or removal of the bed is required for installation.
Kit Includes:
(2) 16" Fox Air Shocks
(4) 2" X .250" wall DOM links
Available Options:
Trail-Link Four™ Rear Kit w/16" Fox Air Shocks, OEM Housing, 110179-1-KIT, Post Up or Call for Price!
Trail-Link Four™ Rear Kit w/16" Fox Air Shocks, Rock Assault™ Housing, 110180-1-KIT, Post up or Call for Price!
Trail-Link Four™ Crossmember
You will need this crossmember if you are looking to put your own kit together. It is designed to fit between a frame width of 36.69".
Trail-Link Four™ Crossmember 110128-1-KIT Post Up or Call for Price!
20 Degree Lower Axle Brackets
Driver and passenger side 20 degree lower axle brackets.
Available Options:
Trail-Link Four™, Axle Lower Link Mount, Driver Side, 140224-1, Call
Trail-Link Four™, Axle Lower Link Mount, Passenger Side, 140225-1, Call
Upper Link Mounts
Upper link mounts fit either Toyota and Rock Assault™ housing.
Available Options:
Axle Housing Upper Link Mount, Rock Assault, Call, 111261-1-KIT
Axle Housing Upper Link Mount, Toyota, Call, 110116-1-KIT
