just fyi, they are a bitch to install. the top stud is thicker than a stock motor mount so you have to drill the plate that bolts to the engine to a half inch. just my .02
Note: In order to install this motor mount, the motor mount bracket on the block side will need to be drilled out from 12mm to 1/2". Some drilling and partial disassembly required.
Ok, that's what I was gettin' at...it wasn't just the drilling! Apparently the final fit isn't great....:awesomework:
The mount holes are slotted so that the Bomb Proof Motor Mount Kit is easy to install and can be used on 3.5 inch and 3.75 inch applications. You don
when i installed a set it was a pain to get them to line up on the frame holes. but drilling the bigger hole wasn't a problem.
so your truck burns a quart of motor honey a week and you spent $100 on motor mounts? :scratchhead:
A chain is free.
