Trailer Pictures
JNK-RNR
Cottage GrOrego
Post up pic's of your Trailer. Please include specs, ( type of deck/tie downs/brakes/length/tire type etc.) as well as any opinions you might have both positive and negative. Feel free to include price as well as the location of purchase.
2pwrlftrs4u said:
Only some ass hat like you Kyle would post your tornado prone accomidations on the web:flipoff: ...BTW, I really like the rebel flag door screen.
..but here is mine
Bulldog 7000# GVW
Ball: 2 5/16
Trailer Weight: 1700#'s
Axles: Tandem, dual brake, easy lube
Length: 16 ft
Deck: Douglas Fir, non treated (I have some lin seed oil to put on it when the planks dry out
COST: $1750.00 for trailer $75.00 for spare tire 1% of cost for using debit card $15.00, no tax for Oregon Resident.
You're gonna want to move that license plate mount somewhere else, first bump you hit on a FS road and the plate is gonna get hammered.
8'x16', 12,000lb capacity.
wood deck
2x8x.120 I-beams for frame rails
2x7x.120 I-beams down the sides and center
7x~20" .120 plate for cross members, every 2'.
1/4" plate fenders
2 - 6,000lb 4" drop trailer axles
245/75R16E tires
Only picture I have handy is the one below. Picture below, estimated weight based on tire buldge was 13-14,000lbs.
Only thing I plan to change is put in cut-outs in the back for the ramps. The ramps alone weigh about 80lbs each, getting tired of picking them up all the time.
wood deck
1/4" plate fenders
245/75R16E tires
that doesn't look like it has near enough weight on the tongue..
It had nearly 2,000lbs before the big boulder was put on the back. then it had none or real close to it.
I was only transporting these suckers within Tahuya going 5mph, so I wasn't concerned. If I was to go on the road I would be much more carefull about how it was loaded.
Heres ours,
2004 Thor Pak Rat
14'x8'-2" deck (expanded in center, solid sides)
Sink, two burner stove, fridge, indoor & outdoor showers, toilet, ac/heat, fold out front bed, fresh, grey & black water tanks,
pbmcauliffe said:
Heres ours,
2004 Thor Pak Rat
NICE!!! :clappy:
2004 Desert Fox.
Sleeps 9 easily...
100 gal fresh water, 4k generator, 35 gal gas tank, satelite ready.
oh yeah it is for sale to.
hauls the sami and 2 quads standing up, or 5 quads on all 4s.
pbmcauliffe said:
Heres ours,
2004 Thor Pak Rat
that is PIMP!! me likes... how much will the back deck hold?:cool:
Boonie Buster said:
what's the width on that trailer??? just curious cus the rape bus is a lil wide:redneck:
If they haven't changed the design since I got mine in 2002 then the width is ~80". The bulge (3psi in the tires) on my 38.5s just barely rub the fenderwells. My front end is 78" outside to outside of tire...the bulge adds about 1" to each side.
pbmcauliffe said:
Rated for 4700lbs, trailer as it sits is like 2300lbs if I remember correctly.
Sweet it could haul my jeep easily, or if towing a heavier load you could beef it up im sure
