tranny cooler ???
i dont have mine mounted in the rear, but i prefer the derale twin circut. one for the trany ,one for the power steering.
Mr. leafspring said:
COME ON GUYS little help here
I'm sure you could call Griffin or any of the other big manufactuers and get whatever you need to fit in whatever space you have.
You didn't give ANY info as to how much room you have, how big of a cooler you need, what you are going to be doing with the rig or what!
Hell, you could spend $1000 easy on just a cooler and fan setup,
OR
you could get a big trans cooler from the front of a Ford F250/350 or E250 van and put your own fan on it.
What kind of money are you looking to spend?
i run a th350, with -6 lines and this derale double pass cooler with a fan, i could get the trans hot but only every once and a while.
i'm now running a cbr double pass cooler. it is much larger with -8 lines. you can't hardly get the trans hot. during the past two ecors races, i've got it up to temp but never hot.
yeah sorry bout the lack of info jus thinking of random feedback guess that's what I got huh :o :o anyway im running a th350 for my 321 chassis thinking of running in back of buggy beside the radiator cause figured up in front by engine heat might not work as well
thanks again !!!!
