Here's my situation, will try to provide as much information as possible...
Truck is an 81 SR5 with a 5 speed that the data plate declares is an L52, haven't verified that by looking at the actual tranny yet bt seems to be kosher information so far.
Anyhow, back to the noise..
Seems I have a grinding/whirring noise coming from the general transmission area when the clutch pedal is NOT pushed in. Also seems to make a touch of a grinding noise while ACCELLERATING in every gear except 4th. No noise while coasting/braking.
All bellhousing bolts seem to be fine, so I'm reasonably sure it's not a motor/transmission alignment issue.
There was a smidge of brass looking shavings last time i changed the trans fluid, soooo...
...that leaves me with guessing I've got a bad input bearing, but I figured I would post up here and see what you gys think too.
Also, if it IS the input bearing, what do you guys suggest to fix it? Is it worth tearing it down and replacing just the bearing? is there a way to just replace the bearing without tearing the whole thing apart? Or am I better off just finding a better used transmission for like 100-150??
