trouble shooting the coolant system.
Jeepless
Sleep deprived and proud
Brier
Ok so on my way to work this morning, I do the normal and status the gauges, on the freeway...well the temp is pegged and I am stuck on 405 in kirkland where there is now damned shoulder cause of the construction. Here are the symptoms
peggs the temp gauge for a bit, no heat out of heater, then it acts like the thermastat opens and heat comes out. and then it repeates this all the way to work:wtf:do thermostats do that kinda crap?.......and home then the lower hose goeswould it have been just the hose?
now I am going to replace the hoses and the thermastat...hoping its not the water pump or radiator, what I need is some advice if there is any on how to tell if it may be worse that I think????
Any ideas???
If the hoses are weak they will do that. They will expand like a balloon and make the engine run hot.
Check the rest of the hoses (including the heater hoses). And yes replace the thermestat. It is probably weak from being to hot. I just went through all this with mu Ford and my Subaru.
Your rad will also do the same thing if it is real old.
If it was full of coolant try a new T-stat first. If that doesnt fix it have it checked for a leaky head gasket, assumimg the guage reads correctly.
I am pretty sure the gauge is good, I have the t-stat and hoses, will update tomorrow....
thanks guys, you have just reasured my thoughts.
Kinda sounds like a vapor lock. Did you service the radiator lately or do anything to the coolant system?
nothing at all. but then again I am not sure how long it has been since anyone has done anything at all to the system!
The only way a vapor lock will appear on it's own is with a leak of the coolant somewhere. But if you dont see coolant laying on the ground it's probably not a vopr lock.
I think the best thing you could do is buy a new thermostat, flush the system and start from there.
0 Words
