Sold/Expired Turbo ls buggy PA
Kurtasmur
Member
5.3 aluminum block
Texas speed 220r cam and pushrods.
Pac racing valve springs
60lb injectors.
Stainless steel headers and up pipe.
Borg warner s366 twin scroll turbo.
Twin 44mm wastegates
Turbosmart BOV
Gm 3 bar map sensor.
Swap specialties standalone harness.
Speed density tune.
Aem meth injection (to cool intake air temps)
Summit racing fuel pump 385lph.
Jaz fuel cell.
Billet summit fuel filter
All fuel lines are black AN lines and fittings
Coolant lines are -20
Goatbuilt alt and ps pump brackets.
Psc tc pump
Summit racing radiator,twin electric 10" fans
K&n air filter.
3" exhaust with bullet muffler.
New alternator.
New starter.
New water pump with -20 billet thermostat housing
New tensioner
New serp belt
All new plugs and wires
Spent close to a full day of tuning on the dyno and tons of drivability
ReBuilt th350 trans with stronger sprags
B&m trans cooler
Full manual reverse valve body
Winters sidewinder shifter
Northwest fab atlas shifters
2500 stall converter.
Advance adapters flywheel kit
Advance adapters tcase adapter
Atlas 4.3:1 1350 non cv yokes
Wide open design drive shaft kits .25 wall tubing
Wide open design midshaft kit
Wide open design carrier bearing kit
Wide open design limit straps
Optima red top battery
Ballistic fab battery box and hold down
Dana 60 kingpin
Barnes high steer arms
Detroit locker
5.13
Chromo inner and outer shafts
Yukon superjoints
Psc double end ram kit
Artec truss
Rcv slugs
14 bolt
Spool
5.13 gears
Disc brake kit
Pinion gaurd
King 2.5 air shocks in front
King 2.0 shocks in rear
Twin wilwood pedals (separate pedals to control rear and front separate
Longacre steering wheel with quick disconnect
Wilwood master cylinders
Nickel copper brake lines
7/8 heims 1.75" dom 1/4 wall arms
Quickcar switch panel
USB power port
Rzr seats
40" maxxis treps
Tmi bead locks on soft eights
Chassis made by rockwood offroad
19k obo
Re: Turbo ls buggy
Kurtasmur said:
Located in PA
Man, don't take this personal, but what is it with people trying to sell stuff and being reluctant to post where it can be seen? I understand not posting an address or a 10 digit grid, but city and state helps folks decide if it is a reasonable drive or not. I hate when it is like pulling teeth to get information from a seller.
It's not just you. I tried to buy a trailer this weekend and had to ask the guy 3 times where it was located. Finally had to explain I wasn't looking for an address so I could come and steal it. Just wanted to know a general area so I could plan my day around the drive.
Looks like a cool buggy with a good parts list. But...all day on the dyno and no numbers posted?!
Made 333whp 366tq on the 40s. Did a 1/4 pull at 13.2 If I knew how I'd post a video of it
I want to buy another rig and pay some crap off lol. The usual. I don't keep stuff long. My last buggy one i had out 2-3 times and got rid of it and built this one
money_pit_yj said:
Why you selling it?
Ive wheeled with this unit a few times, makes good power for sure and he's a hell of a guy. Someone is getting a great deal :dblthumb:
