Price Drop-
This is a mean machine and would make someone an awesome Rockbouncer, Ultra 4, prerunner, or trail rig!
Specs: 120" Wheel base, 20" Belly, Rear Steer, 86" Width, 72" Tall
Engine: Custom Built LSX block built to 454ci, Trick Flow heads,11.5:1 Compression, Dry Sump, Custom Stainless headers, and Inconnel Wrap, 4" Magnaflow mufflers, Injector Dynamic injectors, Fast 102 Intake and fuel rails, PTM 102 TB, Edlebrock Water pump, Mechman Alt, ARE dry sump. Dual Advanced Air Cleaner intakes.
Trans: Hughes 4L80 Manual valve body. (built well) Runs through heat exchanger.
Tcase: Profab ( 2.25 and 1.82:1) Has fluid pump and runs through Heat exchanger.
Driveshafts 1410 From High Angle Driveline chromoly, heat treated spline
Shocks/CO:Rear- King Shocks 3 x 18 Race Bypass 4 Tube (Black),King Shocks 2.5 x 18 Performance Coilover w/ RR (Black),King Shocks 2.5" x 2.5" Bump w/ Can (Black), Front same package 16" Throw.
Links: 7075 2" Upper and 2.25" lower( soon to be Steel) Aurora 1.25 heim joints all around.
Steering: HOWE TT pump for front, Rear is Howe TC with Stazworks 3 function return to center rear steer kit, and coolers. Orbital Valve, and howe double ended rams front and rear. Relief valve.(in cab manual rear lock out)
Axles: Custom Ruffstuff 14, Solid 14 Thirds. Ouverson 40 Spline gun drilled inner, 47 Spline stubs, Violator u joints, Super 7 Hubs, 47 spline flange(ouverson) , and Ouverson Double sheer steering arms. Spools.) 5.38 gears, Remote Hydro Boost/Single Pedal dual reservoir.
Seats Beard RX3T – team tech harness.
Warn 9.0 RC Winch with 3/8 rope
Wire/Engine Mgmt/ Gauges all MOTEC, milspec, and duetsch connectors.(PDM 30, M84, and Race guage, Ignition igniter, cdl3 display)Wiring in the car: Smokeless aircraft Tezfel wire, all wire sheathed in a Raychem chemical and abrasion resistant material. All connections strain relieved with service loops and glue shrink to the connector housing.
Fuel Safe approx. 30 gals custom cell made for the nose. Dry break, and twist cap) Fuel in and out cut off valves.
Holley dual Fuel pump(2 in 1) pre and post filters. And regulator
Radiator: Ron Davis 34x19 with (two) dual heat exhangers.
Lights: Baja designs squadrons(6), and interior LED lights all over. PCI Race radio kit with 110watts, Bluetooth. 7" Lowrance. Has Moroso catch cans for all fluids.( Lost one light at KOH 6")
** Just added - NEW OUVERSON Alum hubs, and Spridertrax Brake rotors, and 6 piston Wilwood alum brake calipers. released about 180lbs****
**Has fresh transmission installed. Car has a few dents and dings, which is part of the sport. It is being sold as is.
40" maxxis Trepadors Comps with 17" Trail ready HD wheels 4.5 BS(Qty 4)
$160k Serious inquires: Email- mjbergman(at)me.com
AS A ROLLER~ $95K
Specs: 120" Wheel base, 20" Belly, Rear Steer, 86" TW, 72" Tall, 2" DOM .120wall chassis All aluminum skins and panels with Dzus fasteners
Tcase: Profab ( 2.25 and 1.82:1) two sets of gears. Runs a divorced style transmission and has a Mark Williams coupler.
Driveshafts: 1410 From High Angle Drive line two sets. Heat treated Chromoly spline shaft
Links: 7075 2" Upper and 2" lower DOM .188 sleeved alum inside.Aurora 1.25 heim joints all around.
Steering: Stazworks 3 function return to center rear steer kit,Orbital Valve, and howe double ended rams front and rear.
Brake Pedal is CNC, and has a remote hydroboost pump, trophy truck throttle pedal.
Axles: Custom Ruffstuff 14, Solid 14 Thirds,Custom inner axle seals and outer, Spools 40 spline, Ouverson 40 Spline gun drilled inner, 47 Spline stubs, Violater u joints, NEW Ouverson Super8 Aluminum Hubs, 47 spline flange(Ouverson), New Spidertrax brake hats and rotors, New 6 piston Wilwood calipers, and Ouverson Double sheer steering arms, 5.38 gears(light axles)
King Shocks 2.5 x 16 Race Bypass 4 Tube (Black)
King Shocks 2.5 x 16 Performance Coilover w/ RR (Black)
Qty:4- Trail Ready HD wheels and 40" Maxxis Trepador stickies
AS A ROLLER~ $95K
