V8 engine options
boxboy
can I be your friend...
Monroe
How would the 5.2L Magnum V8 from like a 1995 or newer Cherokee work in a buggy?
and what a can be done with the transmissions I think those cam with like a 44RE/RH or a 46RE/RH auto can you put a manual valve body in them?
In my Jeep I am running a 1990 4.2L I6 with a Mopar IF kit modeled after I think the 1995 IF wrangler.
The V8 question is for some thing else in the works...
The 5.2 magnum is a little heavy for a buggy, isn't it? Cast iron block, heads...
The 46RH that came behind them in the ZJs is the offspring of the torqueflite 727 so, well supported.
To build or buy a 727 can get expensive, especially when you use a reverse manual valve body. For me chevy trannys are great because it costs me about 500$ to rebuild them. I had a shot to buy a dodge truck V-10 motor, but could not find an adapter to TH 400:mad: The V-10 is 488 cubes of small block snap, with big block torque:masturbanana[1]:that would have been cool.
Are you saying some of the Mopar engines you can get an adaptor to run th400? that would be great it that is the case?
