billstoy
- Joined
- Sep 29, 2011
- Messages
- 1,411
- Reaction score
- 36
I'm running a 16" FOA coil over. I'm running a 18" X #100 bottom and a 10" X #80 and a 4" X #25 take up spring . They never bottom out! I had way to much body roll due to spring rates. I added a currie rock bar with their longest arms and lightest 36"swaybar . this has caused a much stiffer ride , and of coarse less body roll ! none of this was a surprise . I am happy but I would like to lighten the spring rate and make rock bar work harder to get a little more body roll/ spring flex but not as much as without rockbar! My buggy does so good but I would like a little more droop and flex , Even if i go to a shorter shock the spring rate and flex would be the same ! any ideas? ??? my buggy is a crawler not a racer ! no air bumps the fronts work well from full extension to full bottom out. I'm very happy with their rates. I have to say it is awesome to see 42's with one side at full extension and the other at full bottom and with the rock bar buggy will be nearly level! I love this stuff !! May be I could lengthen the arms but i'm not sure if I have room it's a tight little buggy.
