Water in the fronts over there?
elf_cruiser
Member
Just curious as to whether or not you guys are running water in your front tires for all that right coast slippery sloppery wheeling? Anyone tried it?
Non comp guys dont do it, I've seen some pro mod rigs and such on trails that had em ( most memorable the TJ up at Tellico ) and it worked wonderfully.
I think for a trail rig and the types of wheel speeds we see on some steeper loose things it would be torture on parts... I personally dont see the need for non comp use. But Im horribly lazy too. :flipoff1:
mo aka ~rckcrler~ runs water in his reds out here.... seems to work good but they re heavy as fawk.... {but he doesnt wheel that much molaugh}
in a general trail rig unless you are hill climbing all the time I would say dont bother. it does make a difference when you get on the big up hill portions though. it does fatgue parts much faster as well.
Cool beans - I guess out here the only spots we have much trouble with are the big vertical ****. Anything that's like technical crawling is usually doable with very little throttle when it's dry (364 days a year) :P
Basically - some of the climbs out here just about require it, and on many others it at least helps - but not as much as stickies...
I was just curious - thanks!
