pos97TJ
I finished my 97 TJ just to wheel it once and start a buggy build. Well I had to much on my plate so the buggy got the axe and I am building up a spare jeep I had laying around. I got a clapped out YJ renegade rust bucket as part of a deal and figured it would make a great budget wheeler. I didnt take many pictures up to this point so Ill give you a rundown of what I did. First I ripped off all the :rb: plastic body kit, next I built some sliders and tube fenders for it and threw on some modified genright rear full corners. I also had a cage layin around that I built for a TJ so I threw it in the jeep and mounted some seats I had laying around to it. I also had an external mounted slave cylinder bellhousing and input bearing retainer so I converted th clutch to that and put in an atlas 4.3 tcase. I then cut the floorboards out and rasied everything up for a flat bellpan, made a new crossmember that is seperate from the skid and mad some new floorboards. I also slapped on some OD green paint while I was at it. So this is where the pics start....
Here is an over all view of it as it sits
Here is the Tcase crossmember
