crash2
-Oh no I picked a side-
So since I am finally getting my rig up to par I figured it was time to also go thru what I got and update it all. I have always prided myself on being self sufficient in the woods and I like to do the occasional solo runs.
So tonight I started with spare stuff I carry.
- Serpentine belt
- Hydro hose with fittings (When I rework my rig I will convert to the replaceable ends and just carry a chunk of hose)
- Fittings at the ram (90 degree elbo's)
- ARB hose, switch, solenoid and pressure switch
- Fuel pump
- Valve stems (rubber and metal) and valves
- Toyota trunnion bearings
- Small selection of nuts/bolts (both standard and metric)
- Small chunks of steel
- Couple 3/4 hiems with 3/4 to 5/8 insert
- Bailing wire
- Nylon rope
- Garbage bags.
- Selection of wire crimp stuff from butts to eyelets
- Some chunks of wire
- Couple relays
- Cotter pins
- Zip ties in different sizes.
- Front axle U-joint
- 1310 U-joint and U-bolts
- 1350 U-joint and U-bolts
