Just wondering what foams you guys are using with the rover tires? Saw rovers on sale at CKRC for 10.99 a pair.
check out the proline oversize 2.2 foams dual stage , you can get them at www.tcscrawlers.com:;
I'm now running the novas ark dual stage foams in my 2.2 rovers and my 1.9 flatirons.....what a difference! no more tire collapsing on undercuts or getting stuck in holes. And Eddie also sent me some single stage 1.9 foams(not memory foam) to test in the new 1.9 rovers(red compound). Hopefully my darksoul beadlocks and 1.9 rovers arrive before the comp on sat so I can test them.:corn:
I need to get a set of those foams..
Crash, can your rig run axial wheels? if so you can run my wheels and new white rovers with the novas dual foams at the comp. I'm only running my 1.9 as my 2.2 has rear steer...the tire/wheel combo weighs 9.5 oz ea.
Brent
Close to axial offset--but I wouldn't mind trying them out to see how they work. Nice thing about those foams is they don't have the reaction to temps like memory foams do.
Thread hijack
Crash I put a mini torquemaster in the 1.9 and I get an intermittant stall....the led's on the reciever and esc are on when this occurs so it's not a power issue with them and the pinion mesh is perfect. Someone from the rc crawlers board said it needs a break in( run forward for 15 min with small load to set brushes) I did this and it worked for 2 packs but had the same prob with the 3rd pack. Any ideas on what to try next?
Brent
hijack over
Mr Blue (sorry cant remember your real name) I wanted to let you know I looked in my pit box after we talked for those silver brushes.What I had was the stock ones I had replaced with silvers.I forgot to tell you and didnt want you to think I had blown you off.
Good luck with getting it up and running, if you have acces to a com lathe,just cutting the com might help it out also.
