What is the best perches for a SOA for a 1991 yj
popcancherokee
Spanaway
I'm looking for the best perches to use on a soa.I have read allot and still a little confused.Seems like more is good since it is off set.But they come with 2 off set and I only need or want one off set.I'm putting in a non disco front axle out of a Cherokee.Is there any one out there that sells one off set and one normal.or can I just use two non off set and will it line up.Any input would be greatly appreciated.Thanks
Ruffstuff
give them a call and tell them what you are doing and they will get you the right parts. (you dont have to order the perches in pairs)
but on a side note, why are you swaping the front axle anyway? If you dont want the disconnect, just get a TJ long side D30 shaft. Swap that in and you eliminate the disconnect.
