What master cylinder?????
Budget YJ
Silver Creek Ga
I'm stuck trying to order my master cylinder....any help would be nice.
Thanks ahead of time.
I'm going to have two, one for the front and one for the rear but dont know what to order. :dunno:
Ive got to use floor mount so that leaves me w/ 6to1 pedal but dont know about the rest.
1. CMB-14-0010 Summit® Master Cylinder and Pedal Value Packs
Combo, Wilwood, Master Cylinder, 1.000 in. Bore, 1.430 in. Stroke, Pedal, Floor Mount, 6:1 Ratio, Kit
2. CMB-14-0009 Summit® Master Cylinder and Pedal Value Packs
Combo, Wilwood, Master Cylinder, 0.875 in. Bore, 1.430 in. Stroke, Pedal, Floor Mount, 6:1 Ratio, Kit
3. CMB-14-0008 Summit® Master Cylinder and Pedal Value Packs
Combo, Wilwood, Master Cylinder, 0.750 in. Bore, 1.430 in. Stroke, Pedal, Floor Mount, 6:1 Ratio, Kit
What calipers you running?
Get the most pedal ratio you can or get two seperate MC's like P say you have two pedals
It has stock 1ton all the way around as of now, but thinking about changing them out to 1/2 ton to get more wheel clearance.
Matt O. said:
Get the most pedal ratio you can or get two separate MC's like P say you have two pedals
I'm gonna have 2 pedals/cylinders so I can do front and rear digs :woot:
It will also be nice having the separate systems....if one fails for some reason you have a backup to get back with.
AT LEAST..........swap them fronts out for 1/2 ton stuff......
TAKEM LOTTA JUICE...MOVEM BIG CALIPERS.......... ;D
