al1tonyota
I bought a 2008 LS3 with supposedly low miles. it has variable cam (getting rid of) non DOD(Displacementondemand) and is a FFV(flexfuelvehicle) which has the largest injectors.
Basically Im wanting a list of Modifications that need to be done like oil pan, pcv, ect. looking for power and RELIABILITY!
Thanks In advance!
Thanks In advance!
. But it isn't required. There are exponentially more people in the world making serious power with ultimate reliability using stock ECM's than there are using Mast. At least with stock stuff there is a chance in hell that you can find a replacement in a pinch from multiple sources. With Mast you know everything is always a mere UPS shipment away and not on weekends with only one source for technical expertise except on weekends. I think they even use their own unique data port, right? So if you have issues and don't have your laptop with you, forget trying to use a cheap scanner?
