Wheel Stud Sizes
BamaTJ
Hardline Crawler
Gardendale, AL
So talking with Camburg about these KMC wheels I have to have a lot of specific info since they are built to order. Bolt Pattern is a given and for my axles is 8x6.5, but how about wheel stud size? I know the Ford 60 has a smaller wheel stud and the 14b, but I want to have the wheels all the same so I can swap them front to back like I do now. I believe the front wheel stud size is 9/16" and the rear is 5/8", so I am guessing both should be drilled to 5/8"
For reference here is the order form in PDF that I am having problems with.
[attachment deleted by admin]
You would have to get it drilled to fit the 5/8 so that it would fit all your axles.
What is the measurement of wheel stud hole in the wheels you have now?
No idea, I just went with the standard 60 degree acorn as it is universal. Thanks for the help
Get it drilled 5/8 and buy bigger acorns if you need to. I don't know for shure, but you used to could get washers for a larger hole. They were actually designed for aluminum wheels for when they get wore a little.
