where to start w/ brake lights
TipsyMcStagger
heres my plan.
i've already replaced the bulbs
all the other lights work
next:
fuse
wiring behind the lights
third??? look around the foot pedal? i don't know
this is a 86 chevy
If your brake switch checks out--its your turn signal switch--the brake feed goes thru the switch and its not uncommon to loose it thru the switch....
Glad it was something simple. :awesomework:
it actually started not working again. i think the switch is messed up.
there was a split in power wire from the switch, what kind of dumbass gets power for something from the brake light switch.
i took the split off it (wire was cut and went no where) and tried it and it still doesn't work. all the mechanics of it seem to be working right. do these badboys go bad often?
ahh, that might be it too
because i test the power off the brake switch and it got power when i pressed the pedal.
The split was probably there for a trailer brake controller :;
They usually don't go out very often, but I had a Ford that would eat one every couple of months. Finally figured out the switch wasn't mounted right.
lol yea must've been something like that lol
when i press the pedal the wire is getting power. maybe it is the turn signal thing
I "think" power is suppose to come in and out :eeek: so one side always has power and the other gets power when the brake is pressed.
yea thats true, and its working but the lights don't come on heh.
maybe its inside the wiper/brights switch
few, figured it out.
one of the plugs under the dash, the one on the steering column was half way unplugged
