which brand axle shafts?
04rubi
Let the stickies do the work
Got an 04 Rubicon with the 44's still under it. Runing 37" red's. Broke a superior chromo shaft in rear. Was wondering what would be a stronger shaft. Checked out rcv's and ouverson but don't think they mess with 44's. Any ideas?
Rcv does make 44 shafts for the front
TJ 44 and TJ Rubicon 44 are both 30 spline. I had a customer with a broken 10 Factory shaft in his Rubicon a week ago. I like Yukon personally.
YA WD44-30-32.0 [22.01 Lbs] (MAP $179.18)
Yukon 4340 Chromoly replacement rear axle for Dana 44, 30 spline
Yukon 4340 Chromoly replacement rear axle for Dana 44, 30 spline (26" ->34" CUT2LTH) TRIPLE DRILLED. Yukon 4140 Chrome Moly alloy axles offer a strength increase over stock while retaining a low cost. Yukon 4340 Chrome Moly alloy rear axles come with a limited lifetime warranty against manufacturing defects. This axle is for use in 2.750" brk' offset applications. Fits TJ, XJ, MJ JK & WJ rears.
If I can help you let me know.
Bobby
appreciate the info guys. i got a set of rcv's in the front but they said they were still testing on the rears. looks like i'll go with a set of yukons.
