muchado
While you bitches were out having fun at Clayton... I was busy tryin to get my **** together... Maybe it's a Kansas thing not havin our **** together... or is it just me and kelly that have that problem?
When I first got this truck I did some 36's... Painted it green... It had a carb'd 350 and open diffs, push pull steering, stiff-arse suspension... Didn't work the way I wanted at all. I didn't have the money to do much to it so Big Jim helped me bob, dovetail and EXO the rig--some low budget DIY mods to improve the truck.... I broke a steering arm at Cathouse in August--brakes were feeble, tranny slipping+spewing fluid, carbeurator sucked and didnt run for crap on angles... Truck broke a motor mount and then soon caught on fire in Moab--SOOOO I took that as a sign. Time for Fuel injection.... I chose a Vortec V6 because it's got some decent power and I don't plan on running 1 ton axles anytime soon so it'll help me be a little nicer on the Toyota stuff for a while. The motor swap turned into doubler, tcase gears, hi-steer, techtafab disc rear+1ton booster, airshock 4 link rear, body drop, EXO-delete, corbeau seats, tranny rebuild, etc... Way more stuff than I could handle this spring trying to travel for video shoots and scrape together C's and D's to pass my final semester of college.... Well I walked across the stage so now it's finally time to GET AWN IT with my build.
Did some work this weekend putting together some parts we've been accumulating over the winter. My friends Jarod and Ryan out in Great Bend busted their asses all weekend to help... Way cool. I didn't have my camera so Big Jim took some pics... I wish there were before/after pics of the whole thing.. The truck is totally different. No exo cage and also removed the 3-inch body lift. I am psyched--it's gonna be awesome when everything is done. If you're at EOR this weekend you'll see the truck because Dave is gonna tow it up there for me. It's LOW now... Much less tipsy
Fuel injection baby!!!
bullet-proof home brew MM's engine side, waiting on sanderson headers to arrive to decide on vertical placement for frame side mounts
23 spline doubler, 2.28 up front, 4.7 in the rear front range twin stick.. interior to be cleaned up a bit...
I gots some junk in my trunk... art carr, alum radiator, fan, fuel cell, buncha shiat...
rebuilt axle, hi-steer, green knuckles are the shizzle... Can't see but finally have a aussie locker up front
steering box WAY forward--poking thru the core support...
Stoked to get this bitch done... Hopefully be able to bring it down to Bama soon.
