Who's the best ls 5.3 guy around?
poolman
79
Ok, sick and tired of dealing with my wife's Suburban, 5.3, little over 100k burns a little oil not much but it goes through these spells where it runs like crap, has a miss, may not want to start all kinds of stuff. I'd put a new motor in it in a heartbeat if I knew it would fix it but I'm not sure it's not a computer problems? Any shop specialize in these motors? I've had it to 3 dealers and 2 other well known shops all to have different answers?
Have you changed the driver's side valve cover yet?
also, please describe exactly what it is doing when it acts crazy
07 suburban, it will run fine sometimes, then at random it will start missing, and the wife says once a week it doesn't want to start. Sometimes at idle it will be running fine then it will miss, I can see a very little bit of black smoke, ( fuel I'm assuming) and then it goes back to normal. :dunno:
No I haven't changed it. Something I need to do?
Disable the active fuel management/cylinder de activation bullshit and it'll run and drive better. And it won't suck oil
Did this to my buddy's wife's suburban and it "fixed" it.
How do I do that?
Re: Re:
poolman said:
How do I do that?
I used EFILive and bought a vin key for her suburban. Could also use hptuners.
Or I think you can buy stand alone chips to do it, Google search
grcthird said:
Is it throwing any codes? What did the dealers and shops think was happening?
I think the code was multiple misfires? That's from the last guy I actually trust to look at it, he also replaced a o2 sensor. Everyone else has said, rings, heads, ect but after a compression check everything was over 110 I believe :dunno:
Re: Who's the best ls 5.3 guy around?
Mass air flow
Plugs
Fuel pressure when it's acting up
Vacuum leak
Intake leak
Water in the intake?
Bad air filter
Them stupid ass fuel management lifters (just replaced some on an 08 yesterday) but it was a dead miss so your might be going out
Quoted so I can read all the story in one place. And finally got to a laptop so I can type a decent response.
Check the fuel injector wiring, corrosion on pins at ECM on the blue connector, look at where the harness goes around the battery box and see if it's chaffed and grounding injector wires. Have the motor mounts started tearing up and going thump when you get on the gas? Could be pulling on the harness.
Spark plugs been replaced yet, what did they look like when they were pulled for the compression test?
Fuel pressure good when driving or under load? Pump may be leaking down after sitting all night, or for long period of time. Does it crank right back up if it has only been turned off for a few minutes, like going into the store for a case of beer?
When it throws a misfire code, look at the data stored and see what degrees the coolant temp sensor is at, if it drops to -34 or something stupid then it has a "dead spot" in it and is causing it to go rich.
If it was mechanical, I think it would misfire all the time, not randomly.
Hope that helps, if not tell me to :gtfo:
Also might be computer ****ing up and throwing it into fuel management randomly never heard of it happening but a possibility
When I first got my truck it fouled a plug within the first week and burnt a little oil. Got thishttp://www.rangetechnology.com and it prevents afm from working and have zero problems since
Brand new plugs, old ones looked ok to me
Intake gasket replaced twice
Fuel pressure is good, not sure of the coolant temp
yes it starts good when shut off for 5 minutes, maybe just a few more turns on the starter.
I'll check all the wiring, thanks for the help guys.
And now at idle it will drop down to 300,400 rpm and acts like it's going to die but doesn't? ? If anyone knows what's up with this thing and wants to fix it I'll drive it to you! :****:
