Rjhoward32006
went to plumb my brakes and my new wilwood master cylinder does not have a flare in the end it is just threaded. Do you guys run an adaptor in the end of the master or what do you use to keep pressure on the flare so that it will seal?
As of now the fitting will fit but the brake line moves in and out and i'm sure it dosent stay like that but maybe once there is fluid and pressure inside the master it keeps it pushed out? That leaves just the threads from leaking and no flare?
