Winch cable questions.
KarlVP
Love that TOYOTA
Crustys Brewery
Okay, on my warn 9K my retaining bolt keeps backing out and destroying my cable. I'm done with that system. I know I can't drill a hole through the drum like an 8274-50, so I am left to resort to other options.
What I was thinking of (Actually what Tom thought of) was to weld a small piece of pipe into the corner of the winch drum, run the cable through and use a cable clamp to double it over. I thought this was a mighty fine idea.
Another question. I got a new winch cable and it needs to have an eye splice put in. Is it okay to use cable clips? Like this on my 5/16" cable?
Or should I put a clamp and compression fitting at the new eye?
We have the press to correctly put the compression fitting on the cable at work. But we are out of the fittings. Any ideas on where to get them?
Try greenbank I think that's the name of the place off of broadway across the street from D.O.T. mantance yard north Everett..they should have what you need..
The guys at Dunlap Industrial down on the waterfront are pretty cool too but you gotta go to the little shop south of the main retail store.
1028 West Marine View Drive
Everett, WA 98201
Phone: (425) 339-2666
