Wiring help
GaWag
Active Member
Gainesville,Ga
Getting ready to start wiring. Wiring is not my strong point. I have bate minimal electronics. Anyone point me in the right direction for good info? I've been searching but not having luck.
Kill switch
Push button starter
DUI distributor
Starter
CS-144 ALTERNATOR
accessories i can handle. Thanks if you can.
Use relays for heavy loads such as fans, fuel pump and lights. Everything on my buggy runs through manually resetable circuit breakers that way I don't have to carry spare fuses with me on the trail.
Thank you very much. I agree with the heavy wiring.
What I really need is a guideline as to where everything goes in order from batt to starter, apparently the cs-144 needs some diodes and such. I've been searching and am not finding much help. Almost feels like wiring harness building is a closely guarded secret!
Kerry, it's a bit overwhelming for me. Plus since I'm not efi a lot of the harnesses don't seem to fit.
Werewolf thank you. That's similar to what i found before. I will look further in to it.
Private message and text sent Patrick. Thank you.
