Ok. super simple.
All you really need is an ignition hot to the distributor and the choke(if it has one).
Then you will need an ignition hot to the exciter circuit of the alternator and then a wire from the main lug on the back of the alt to the battery.
Then a crank voltage(push button) to the starter and then a large guage cable from the starter to the battery.
Thats all you need to make it run...
