Would this twist bother you?
vanguard
That rock walker guy
RTP, NC
This is my fj80 rear short side. At first I thought this twist was the cause of my e-locker not locking as it should be it's working now. I ordered cromo shafts and I'm kind thinking about canceling the order. Then again, I kind of want cromo shafts so maybe this is the excuse I need.
So, would this twist bother you at all?
MUCHADO said:
run it... but if you already got chromo's on the way then keep this as a good spare :drinkers:
Yep, that is what I would do. If you run it you will have that in the back of your mind all the time.
What twist? Looks factory to me............ :flipoff1: Run it til it actually does break, which is a long time from now would be my guess. When was the last time you inspected?
wngrog said:
Work hardened. That is fine.
The idea that a permanent twist is work hardening violates the tiny bit I actually know about metallurgy. I started a pirate thread about it: http://pirate4x4.com/forum/showthread.php?t=669035
We'll see. I know it's not a bad twist but I think I'm going to get the cromo's anyway. I'm just convinced that once you bend beyond the yield strength and have a permanent twist you're weakened.
InDaShop posted while I was posting. That pic is from today.
