What kind of shackles do you guys use? What do you think of the revolver? Whats the max lift you can put on without having you worry about a SYE?? You guys got pictures at all of the articulation that you claim is better? If I spring it over I am going for the RE for sure the was the plan but at the same time I dont want to use the stock axles and with the spring over it gets to be alot more $$$$ for the lift.. because if you SOA it you would need new, springs,new shocks, sye and shaft, etc. All that adds up real fast to well over 1k after the lift is done.. Probably the best way to go but the most expensive also..
