:clappy: Now, I'm pretty sure that you won't get the same lift putting XJ coils in a ZJ, due to spring rate---if you know the part number of the XJ coils, or at least the brand-you could probably figure out whether they would or not...:awesomework:
As I stated before, the ZJ's are heavier, therefor would need a heavier spring rate to compensate for this, an the XJ's are a bit lighter. My guess is, with a 3 inch XJ spring, you will probably get 2-2.5 inchs of lift depending if you have a V8 or not
