2 seat 4800 style buggy
bryon
Member
2 seat buggy.
113" Wheel Base
82" outside of tires
Weight with tools and water in front tires Approx. 4200
Suspension:
Front four link with 16" x 2.5 King Coilovers with Res Lower Links 2" Chromo/Cryo Treated Upper 1.75 Alum 1.25 lower heim and 3/4 upper heim
Rear four link with 18" x 2.5 King Coilovers with Res Upper Links 2" Alum Lower 2.25 alum sleeved with 2.5 Chromo 120 wall. 1.25 heims on lower and upper rear. Upper front heim 7/8.
Drivetrain:
Engine:
LS2 built by Texas Speed and tuned by Tempe Performance. Cam/ Chromo Crank/FAST 102mm Intake/Fast Fuel Rails, dual spal fans on Ron Davis Radiator. 3qt Accusump. PacFab oil pan with weighted traps
Transmission:
Reid TH400 Case a TCI 2800 9" Billet Torque Converter
Transfer Case:
Atlas 4.3 with 32 spline f and r output
Front Axle:
Prorock dana 60 all CTM axles and CTM U joints. 4.88 Gears and Reid Knuckles with 3.5x ½ tube. Artec High steer arms with Lost Off Road tie in kit and solid brass bushing for kingpin upper
Rear Axle:
GM 14 Bolt with upper and rear truss. Ballistic shave kit and cover. CTM 300M Axles 40 spline at the hub. ARB Locker and 4.88 Gears.
Steering:
Howe Trophy Truck Pump with spare/10 inch Howe ram/ Howe filtered oil res/Howe Pressure Release Valve.
Seats:
BS Sand ultra style seats with Mastercraft 5 point Cam lock Belts.
16 Gal Bladder Jaz tank with two inline fuel pumps..
Wheels are BAD internal Beadlocks with monster valve. Tires 39" BFG Reds in good shape
Rugged Radio RM60 Radio with two headsets
55k
In Big Bear Ca
Text for pics.
909-838-962 $ix
Edit: Apparently it was an issue on my end as the pictures originally posted but didn't show on my end.
Cool looking buggy. What material is the chassis made out of?
I couldn't tell you for sure.
It was well made, I'm assuming at least DOM.
Text if it's easier.
909-838-9626
