38$ posi lock
Bamafan1277
I made my own posi lock today for 38$ and works great. 9ft choke cable from NAPA only ones that have it. 32$ 1/4 inch compression fitting and a 2 inch spring. Drillied hole in actuator tapped it out for the fitting drilled 2 holes in fork. Ran cable from cab along top of axle zip tied it down. Trimmed the excess cable off installed spring between fork and fitting thread cable through spring into one hole in fork and back through the other hole on the fork and tied it off. I put everything back together under jeep.
