scooter60
- Joined
- Sep 30, 2013
- Messages
- 414
After a ton of thought and apprehension, I am putting my crawler up for sale. I just don't get out enough anymore to warrant keeping it around and I would love to see this go to someone that will use it more than me. Here are the details:
85 Toyota Rockcrawler
Clean and clear title. This truck is currently plated and insured. I do drive it on the street occasionally.
Toyota cab and frame. Frame has been plated/repaired and strengthened. *Custom 1.75" .120 wall DOM Exo-Cage tied in to frame(multiple roll bend accents)
*Full Toyota doors and custom tube doors.
*43" Interco Super Swamper SX STICKIES
70-75% Tread(NO holes, plugs, or patches)
*17" Aluminum Raceline Beedlocks
***Drivetrain specs***
*GM TBI 350(stock motor)New Affordable fuel injection wiring harness. Custom ECM chip
**TH350 Transmission. Reverse full manual valve body. Slightly higher than stock stall.
**Northwest Fab 203/205 doubler
transfercase(BiIlet PTO cover and output bearing retainers) with 1410 yokes front and rear. Triple stick shifters(front dig capable)
** 1410 drivshafts front and rear built with
2.5" .25 wall DOM.
**GM Dana 60 front axle. 5.38 gears. Yukon spool. Yukon chromo axle shafts and superjoints. Yukon Hardcore hubs. Stock 1 ton brakes. Barnes 4wd truss. PSC full hydraulic steering w/2.75" double ended ram. Sky Offroad high steer arms with knuckle tie in. Bronze king pin bushings.
Custom steering ram mount built using .188 wall DOM. Solid Diff cover
**Corporate 14bolt rear axle. 5.38 gears.
Mini spool. Yukon chromo axle shafts. Disk brake conversion. Diy4x axle truss w/ pinion support tie in. Barnes pinion guard and 13boIt Diff cover.
***Suspension***
*14" ORI struts in the front. 4-linked. 2.125" 7075 lower links w/ 1 .25" heim joints. 1.5" .120 wall DOM uppers w/ 7/8 heim joints.
*63" Chevy leaf spring in the rear w/ custom center mounted traction bar(NO AXLE WRAP). White shocks.
***Interior Details***
*PRP daily driver seats w/ PRP 5.3 padded harnesses
*15" Aluminum Longacre steering wheel(removable)
*Winter's Rock Gate transmission shifter w/ reverse pattern
*Custom stainless and aluminum triple stick transfercase shifters
*Custom 12voIt Guy.com switch panel(keyed for security) w/push button start
*In-cab Winch control from 12voIt Guy.com
*Custom gauge cluster w/ Glowshift
Gauges(OiI Press, Water Temp, Trans
Temp, Fuel Guage)
*Pioneer Head unit w/ Kicker dash speakers and Kicker 6.5s.
*TYT UHF/VHF 2way radio. 25 Watt.
* Multiple USB charging ports
*Heat/Defrost
*Glass windshield w/ wipers.
*Sliding rear window.
***Miscellaneous***
*Full PSC steering setup(Steering valve, Reservoir, P-pump, & Ram) field serviceable hoses.
*GM 1-ton Master Cylinder. Coated, braided brake lines.
*Rear mounted aluminum radiator w/ custom schroud and twin 14" SPAL fans on thermostat
*Derale Atomi-cool Transmission cooler w/ fan also on thermostat.
*Complete rewire w/ BustedKnuckIe Offroad relay box. Waterproof High 120 amp breaker.
*LED headlights w/ highbeams and integrated DRL's and turn signals.
*LED tail lights and reverse lights.
*LED Rock lights( 14 total, lights up really well)
*LED pods on front and rear for Auxiliary lights
*Blue LED under dash lights(turn on with parking lights, also has a bypass switch to turn them off)
*9000lbs Badlands winch w/ synthetic line
*Custom 3" exhaust w/ Magna Flow muffler. Wrapped with titanium exhaust wrapped front to back. Full exhaust system.
*15 gallon RCI fuel cell
*Walbro inline fuel pump
*100 micro pre-filter fuel filter and stock fuel filter
*Aluminum lockable toolbox mounted to bed
*Sinister Fabworks fluid holder(HoIds 2 gal coolant and 4 quarts oil/fluid
*Custom 60" Highlift jack mount(jack not included)
*Ozark Trail cooler mount recessed in to bed
*Spare chromo axle shafts
*Spare 17" steel beadlock
*Misc other Spare parts
Asking $18,000
Truck is located in Mt. Washington, Ky 40047.
Call or text 502-644-5412 for more pictures or questions
2.5" .25 wall DOM.
***Suspension***
Temp, Fuel Guage)
*Heat/Defrost
***Miscellaneous***
Asking $18,000
