IRONMIKE
O.D.
For sale rolling chassis.
2013 BFR Coupe. This is the first one Tim built. Can be configured as a 4 seater, or a 2 seater. Tim set the suspension, engine, and belly pan at time of purchase. Never been outside. Always garage kept. This is an as it sits deal and with inflation the way it is you could not touch this package for the asking price. We are moving and I don't want to bring this rig along.
Engine: 5.3 out of a 2000 truck, wiring harness is stripped and ECU is reprogrammed, never ran, Headman shorty headers. Goat Built power steering pump mount.
Transmission: Fresh rebuilt T400 for 500 HP, Atlas 3.0. used. Aft Carr shifter, new. All 1350 drive shafts and front carrier, all new.
Front: Dana 60, Detroit, All Yukon axles, 5:13, completely gone through new everything. 3/4 ton disk brakes.
Rear: 14 bolt, Detroit, Stock axles, 5:13, completely gone through new everything, 3/4 ton disk brakes. No emergency brake.
Suspension: 14" Fox coil overs all around, used. 4" Fox bump stops, new. Sway away sway bar. Not installed yet. New never installed.
Wheels: HUMVEE rims with custom inserts, 39" Interco TSL Mud Terrains. Race harnesses front and rear.
Steering: 10 PSC with PSC pump, plus spare, and PSC steering valve. All bought used from H.L. Ram is new.
Fuel Tank: Goat built fuel tank with GM fuel pump.
Interior, Front: Corbeau seats up front. Rear: Custom Suzuki seat with matching pattern and material to front. New harnesses also.
I have most of the parts and material to finish the rig on hand. Wiring harness, brake plumbing, floor and roof material, Lexan FJ hood, LED lights, and gauges. Interested parties should only need to source exhaust parts, and fuel plumbing. Lost interest, so my loss is your gain.
Asking $18K. Serious inquires only.
More pictures available for interested party.
Text is best: Eight 5 Nine 2 two nine 1 eight 7 four.
Located in Lexington KY.
