Pathfinder52
New Member
I'm selling my Toyota FTOY. This is a dialed in rig with zero issues. Buggy comes with the trailer, full spare, (3) aluminum propane tanks, (2) steel tanks and much more parts. Located in Cartersville, GA
Not interested in trades of any kind
$21,500 for Buggy, trailer and parts
Buggy Info
FTOY 48
this buggy is trail ready, needs nothing but a driver and is a great trail rig.
-Raceline Monsters 17x8.5 -32 custom Copper powder coat
-NEW BFG Krawler KX 39/13.5-17
-30 spline Longfield's
-Trail Gear drive flanges
-Custom trussed front housing, six shooter knuckles, with high pinion 5:29, spool, TG 2-inch ram, TG power flow pump with cooler, PSC reservoir, ARP studs on hub and arms.
-Marlin crawler tapped steering box
-Trail Gear rear rock assault housing, custom straight axle width, TG rear chromo axle shafts, custom disc brake conversion, Yukon 5:29,spool
-4.7:1 transfer case with twin sticks and 21 spline Bobby Long output shaft
-L52, 5 speed tranny with Marlin Crawler clutch & flywheel
-FROR crossmember
-22RE motor with Got Propane kit
-Griffon aluminum radiator with electric fan and new thermostat
-Trail Gear 5-inch springs all the way around
-Trail Gear shackles, with toolbox guy inboard mounts
-NEW Bilstein 5125 shocks all around
-Trail Gear u bolt flip kit
-Rear suck down winch
-Warn VR10S EVO winch with front suck down
-Corbeau susp seats with crow harnesses
-12 volt guy switch panel
-Willwood brake and clutch assembly, all stainless-steel lines for brake and clutch
-13WG front calipers
-Sky's rear disc and caliper kit
-Baja Designs XL-R Sport headlights with dimmer
-Westin 40" light bar
-X2 Power Group 31 AGM battery
-Amazon rock lights, taillights, and dome lights
-Custom Gold Finger hand throttle
-Lexan side panels with aluminum roof and hood
-NOAM Bluetooth stereo
Buggy Info
FTOY 48
-FROR crossmember
