For Sale Jimmy Smith Rockbouncer 383 Stroker
ToledoDan
2017 Jimmy Smith Rockbouncer
$28,000 located in Seabrook, TX
383 Stroker - 010 4 bolt main block from a 78 chevy truck
10.5.1 compression
All ARP main studs, rod bolts, head studs
Moroso 7qt oil pan with melling high volume oil pump.
Fitech Fuel Injection
Powermaster Mini Starter
Edelbrock Water Pump w/new spare Autozone Pump
More details on engine available
TH350 Transmission w/F250 Trans Cooler
Atlas 4sp Transfer Case (1:1, 2.5:1, 5:1 & 10:1)
C&R Dual Pass Radiator with dual Spal fans, AN -16 Fittings
2.5t Rockwells, Mohawked 3/8" pans, 3/8" boot guards, Overson/Detroit Lockers and Boyce Equipment Chromoly Axle Shafts
PSC Rockwell 3.0 x 9" Stroke Front & Rear Hydraulic Steering (Front Cylinder is brand new)
PSC High Flow CBR Pump
Wilwood Dual Disk Brakes at each wheel
Sway Away 2.5 Air Shocks, 18inch travel with custom valving
Fox 4" Bumpstops
PRP Competition Elite Seats w/heaters
Warn 9.5 Winch with 5/16" synthetic rope
Well Worn 43" Stickies on 17" Stazworks Double Beadlocks-matching spare with 80% tread
2.5 Johnny Joints
127" Wheel Base
30gallon custom aluminum fuel cell with 9 internal baffles
I bought the new chassis from a guy in Missouri back in July of 2017. We finished it in Sept of 2018 and ran it for almost a year to work out all the bugs before stripping it down for powdercoat. We have had an absolute blast running this on some of the best trails in Texas, Oklahoma, Arkansas and Utah.
Spare axle shafts, shock valves & seals, axle boots, bump stop pads, water pump, inner rock rings, fuel filter sock and misc other parts will be included in sale.
If I were going to keep it, I would want to put new tires on it, put on a larger hydraulic fluid reservoir and put a better radiator overfill bottle on it (the one that's on there works fine, it just isn't aesthetically pleasing).
i have a few videos on tiktok ToledoDan
The only reason I am selling is because we just don't use it as much as we used to.
I haven't been on here much, if you want a quick response text 28one-four one four-four 5 ten
