My New 2012 RZR-XP900 - Now a RE-BUILD Thread!!!!!!!
Re: My New 2012 RZR-XP900
Thanks.
It wasn't a pleasant ride for sure.
There were 3 rolling jumps in a row.
They are small and there in the trail just to slow people down.
I guess they worked.
I hit them too fast or not fast enough and the front cleared the last and the rear didn't.
The EBS is engine braking system and I heard that the 2011's are really bad.
When you let off the gas they will slide the back tires when going into a corner.
Kind of like pulling the emergency brake.
I like mine it doesn't start to work until you're below about 15mph and it's not bad.
It really helps going down a steep hill.
Works like a straight shift.
Here are a few more pics.
I'm really glad nobody was in the passenger side.
I was really lucky that my girlfriend had to work.
Starting the tear down and rebuild today!
Got started yesterday by getting it off the trailer............easier said than done :****:
Got it tore down and my parts needed list.
Here are a few pics.
My brother helped get it off the trailer.
Tubing is actually pretty thick compaired to the cage I cut up on my "S"
The stuff on the inside is where it cut through the seat!
It sheered off almost like you cut it.
I would recommend drilling the bolt towards the center (a self tapping screw) all the way through and replacing with a bolt.
It pulled out and was gone.
Rotor and caliper didn't make it.
CV and ball joints to a beating.
This piece is on back order but found one in stock in El Cajon
Rear CV looks like the front
New custom high clearance radius rods! lol
I must be too fat b/c I bent the seat belt bracket!
A-arm poked hole in the wheel
These are heavy...going to do away with these and just weld plate to the ends of the new cage to bolt it on with.
High $$$$$ shock bent
Pile of junks parts
Here's the progress of going back together.
Going to mount a spare tire in the bed since the original bed is busted.
Got a boat load of parts on the way!
Posted your pics on the RZR forum caused a major buzz.
Also on another note my buddys 900 just burnt to the ground so if you don't have all your parts yet let me no what your looking for.
Glad Ur ok man!!!!!!!!!
Def. The worst rzr crash I've seen
Atleast u can say you have tested the Hek out of it and your still walking!!!!
Damn what a crash
Ya bend any tube yet :afro: . I'd like to see you run it at hawk pride when I'm racin on the 10th .
