patooyee
- Joined
- Sep 27, 2008
- Messages
- 5,692
I think if I could be married to a website it would be www.mcmaster.com. It seems like they have absolutely everything and about 1,000,000 things you didn't know of. What are some common things you get from there that others might not know they have?
http://www.mcmaster.com/#52705k37/=tshjnh
Ultra-Clear PFA tubing - I use this for sight tubes on fuel cells and whatever needs one. It is the only stuff that abso-fricken-lutely never dries, cracks, or glazes over time that I have found.
http://www.mcmaster.com/#catalog/120/3513/=tshkfw
O-ring stock for H1 rims. **** buying expensive o-rings from vendors that aren't the right size half the time. Make your own, they work just as good, better really since you know you've got the exact right size.
http://www.mcmaster.com/#catalog/120/114/=tshl36
Weld bungs for fuel cells / other containers.
http://www.mcmaster.com/#catalog/120/3820/=tshlcn
Rubber edge trim - Good for protecting yourself from sheet metal edges that could cut or scrape. I also put it on my fan shroud to keep it from chaffing the radiator and to create a better seal.
