Moto261's Cj7
and put the axel under it and hung some springs
Looks good Dan. I like having the spring pivot in the frame. Makes for a stronger mount and allows a longer shackle without to much lift.
thanks the build been going good i only wish it would be sitting about 4" shorter but i will have to work on that
the front axel and gears all in just waiting for the locker,shafts,and the high steer arm then back at it
dan
got some more parts today :cheer:
and got some stuff for my steering had to turn them down and re-tap for the right size :kissmyass: and all my outers out to be put on :puke:
and all together now i need to do the steering box :mad:
so i needed to mount steering box :cheer:
got the steering done and breaks up front
its been done for a couple weeks and what a blast to drive
and soemm more pix
and some pix from the frist trip
So how was last weekend ? did the radiator hold up under presure or did the fan take this one too:eeek: Find a valve cover yet ?
yea it worked i think i get a new one when i put the v8 in it and waisted $100 on a valve cover had to go all the way up to olympic 4x4 to get one but got to go out on last saturday and play the thing is so much fun to drive
dan
Ouch on the valve cover but at least you can use it. That rad worked ok with my 351 after I put the twin fans and shroud on. Did you want those front flares? Should be around all weekend
