i have a 1989 body,computer and harness on my 4runner with a 1985 motor and frame. the motor does not run correctly as there are plugs "more then one from the harness that do not plug in anywhere and there is at least one sensor or valve that has no plug to plug in to it. this sensor or electronic valve....not quite sure what it is....has a hose that run's directly to the front of the throttle body right under the air fuel screw or what ever it is that you should never mess with. I'm sure it has been messed with and i was woundering if anyone know how far you should back out that screw from the bottoming out to try and reset it. my truck back fires but idels fine but as soon as i step on the throttle it seems to fall on it's face and if i put the thottle to the floor it will run but severly under powered. it is a good motor as just the other day i was doing 70 down the free way no problem to my buddy proporty but when i left i had it to the floor and could hardly do 40 mph. also i have had no luck finding a coolent temp sensor that will fit either of the 2 plugs from the harness that go no where...ggrrrrrrrr i have baught 4 differnt temp sensors and they all are 2 wire sensors. my temp gauge in the truck does not work either! what do i do guys can you help. do i have the wrong intake for this harness. is there a way anyone with a 1989 tell me what color there coolent temp sensor plug is? i have a white plug and a gray plug with no home and i'm sure thats half the battle. also does anyone have a vacume diagram for the 1989 4runner 22re?
Thanks for everything guys you are my only hope.
